Thread: Seismic Design
    2012-08
    4
    Default Seismic Design
    Is there seismic design tutorial? I would like to know how the program generate seismic load and how to distribute the lateral seismic load to structural frames?
    Thanks,
    Peijing Xu
    Glos Associates Inc.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    Default Re: Seismic Design
    Hi Xu,
    The program has several methods of generating seismic loads and unfortunately there is not an already prepared tutorial that I'm aware of. You will find that the help files for Robot are quite good and explain a lot of how the seismic loads are generated by the program. It supports many different codes for seismic load generation, some equivalent lateral force method, some based on spectral analysis using the natural frequencies determined by modal analysis as well as more advanced seismic analyses like pushover analysis to study ultimate behavior of a structure accounting for non-linear (plastic) behavior of the members.
    I would recommend starting with the help files and going from there.
    Hope that helps,
    -Ken
    Ken Marsh
    Owner, Marsh API
  1. Replies: 0
    Last Post: 2015-08-07, 05:37 PM
  2. en1997-1:2008 (eurocode7) footing design and seismic combinations
    By rigid_joint in forum Robot Structural Analysis
    Last Post: 2011-04-01, 04:10 PM
  3. RSA seismic UBC 97
    By mj_lampad@yahoo.com in forum Robot Structural Analysis
    Last Post: 2010-08-09, 03:00 AM
  4. RSA seismic analysis
    Last Post: 2010-07-13, 03:44 AM
  5. seismic forces
    By angel.247184 in forum Robot Structural Analysis
    Last Post: 2010-06-08, 09:23 PM
