Thread: Elevation Difference
    2013-10
    Default Elevation Difference
    Hi, what makes the elevation of a link revit drawing different to the elevation of a host drawing? Please see attached.
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: Elevation Difference
    Quote Originally Posted by bench View Post
    If you copy monitored the linked levels originally, than you should get a coordination alert. Check Collaborate tab-->Coordination review. If you did not CM than you'll need to align and lock your levels to their new elevation locations.
    2013-10
    I linked the revit file via center-center. I tried ti link via origin-origin and this solves the issue.
    2015-11
    Saint Louis, MO
    485
    i wish they would make that the default... who would Ever use center to center on purpose?
  1. 2014: elevation difference between two surfaces
    By WDM2608 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2013-09-24, 10:05 PM
  2. Is there a difference between Interior and Exterior elevation tags?
    By brodie_geers in forum Revit Architecture - General
    Last Post: 2011-03-31, 06:49 PM
  3. What is the difference between ULS+,ULS- and ULS?
    By smm.144 in forum Robot Structural Analysis
    Last Post: 2010-10-01, 10:12 PM
  4. What's the difference
    By Tharwat in forum AutoLISP
    Last Post: 2010-09-09, 08:48 AM
  5. Difference b/w stb and ctb
    By jmyers.67919 in forum AutoCAD Plotting
    Last Post: 2005-03-11, 03:41 PM
