Results 1 to 10 of 11
Thread: LISP REQUEST : Revcloud and insert a evision Tag
    2012-06
    9
    Default LISP REQUEST : Revcloud and insert a Revision Tag
    Hello all;
    i found this LISP over the internet at Swamp :
    http://www.theswamp.org/index.php?to...0307#msg480307
    what it does is you make a Rectangular / Polygonal Revcloud and you have the Option to enter your own Arc Lenghts
    am wondering if it can be modified to add a Attribute Block after creating the cloud.
    what i want is this, if it is not too much :
    1. Issue the command
    2. Ask for a Revision Number
    3. Add that revision number to the to be inserted attib block and also make a new layer in this format : A_RevCloud-(rev.no), if the Layer is existing, warn the user, if not, create the layer
    4. Ask where to put (Model or Paper Space)
    5. Do the revision cloud based on the lisp stated above
    6. Ask for the insertion point of the Attrib. Tag
    my attrib tag is saved in the autocad support folder, RevTag.dwg
    Thanks in advance to anyone who will assist me!
    more power to all!
    I could stop if I wanted to pbejse's Avatar
    2010-10
    395
    Default Re: LISP REQUEST : Revcloud and insert a evision Tag
    I guess you would stand a better chance replying on the original thread Orzabal. The addition you rquire isn't that difficult.
    2012-06
    9
    hello pbejse;
    i tried to register to that site but i cant't. don't know why.
    that is why i posted it here
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Have you searched these forums? I created something similar a few years back.
    2012-06
    9
    i did last night but can't find anything sorry...
    AUGI Addict tedg's Avatar
    in the upper right corner
    2,287
    I wrote a routine (with some help here in AUGI) that you draw a revcloud in paperspace and place a rev triangle, and asks for input for revsion number.
    If you're still looking for one tomorrow, and you would like it, I'll post it, I'm not at a place where I can upload it now.
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    2004-08
    Hartford, Michigan
    3,086
    As did I..
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2,287
    Quote Originally Posted by Orzabal View Post
    Hello all;
    more power to all!
    Here is the routine I referred to in my provious post.
    This puts you in paperspace, sets cloud arc is .375", creates or set layer to G-ANNO-REVS, asks you to draw your polyline (which turns into revcloud).
    You will need to modify it to meet your needs, this calls up a block defiinition (.dwg) called "REVTAG"
    (defun C:rc (/ arc)
    (setq lyr (getvar "clayer"))
    (setvar "tilemode" 0)
    (setvar "attreq" 1)
    (setvar "attdia" 1)
    (command "_pspace")
       (setq arc 0.375); rev cloud arc set to .375"
       (if
           (tblsearch "layer" "G-ANNO-REVS")
           nil)
    (command "-layer" "make" "G-ANNO-REVS" "color" "5" "" "lw" "0.5" "" "lt" "continuous" "" "")
         );look for this layer if not found, create it, set it current
            (command "_.PLINE"); draw pline
         (while (= (getvar "CMDNAMES") "PLINE")
           (command pause)
         (command "-layer" "set" "G-ANNO-REVS" "")
         (command "pedit" "l" "c" "")
         (command "._REVCLOUD" "a" arc "" "O" (entlast) "N");change pline into revcloud)
    (command "-insert" "c:\\lisp\\REVTAG" pause "" "" "") ;;<---need to modify to your block and path here
    (setvar "clayer" lyr)
    Hope this helps
    Ted
    2012-06
    9
    Thanks ccowgill and tedg;
    i will try this out..
    but honestly i am more comfortable with the routine in the link that i've posted
    i'll see if i can combine these two routines...hopefully.
    coz am not that knowledgable in Lisping
    2010-10
    395
    That is the part i don't really understand Orzabal.
    Try this link
    http://forums.augi.com/search.php?searchid=121737
    according to Opie he wrote something similar. I hadn't had a chance to browse thru them, theres only 7.. well 6 if you dont count this thread which includes the keyword "revcloud" and user "Opie".
    HTH
    well....
  1. Request lisp Help
    By jwchambers in forum AutoLISP
    Last Post: 2012-03-16, 07:02 PM
  2. revcloud lisp
    By CAD Brad in forum AutoLISP
    Last Post: 2010-11-04, 09:37 PM
  3. Lisp Request
    By sadikozer34 in forum AutoLISP
    Last Post: 2009-09-06, 08:49 AM
  4. Write a LISP routine to enhance the revcloud command
    By melissa.j.seidel in forum AutoLISP
    Last Post: 2005-11-14, 05:08 PM
