This refers to a true bay window and not an oriel or bow window such as those available out of the box.
The true bay window projects from the main wall of a building and has a wall below the window following the line of the window which usually is angled,
with the floor extending into the bay. This type of bay window wraps around three sides without masonry piers at the corners (that is another type of bay which is easier to create).
Trying to create a family for the window to insert in the main wall creates problems when inserting the low wall under the window..it simply won't join correctly without error, irrespective of using an opening or void.
It also does not recognise the area of the bay when creating rooms
Trying alternatively to create the bay by carrying the wall around the bay also doesnt seem to work, throwing up all sorts of problems unless there are brick piers at the angle corners ( which is not the type of window considered here).
Using a stacked wall with an upper thin wall zone in which the window elements can be inserted as families doesnt work as there are then conflicts in how that joins to the main walls
Whatever strategy to create these I adopt there always seems to be one last issue that revit doesnt like
I've read what seem like hundreds of posts on bay windows, but never yet seen a method that genuinely works for true bay windows.
Given that much of the housing stock in the UK has true bay windows, and planners often require them to be replicated in new work, we need a method to draw them. I assume this is likely to be an issue elsewhere too.
Has anybody truly succeded in creating true bay windows? If so can you please post your method or suggestions?
Thanks
Robin
