Thread: Update blocks for Autocad 2012
    2012-10
    Default Update blocks for Autocad 2012
    Hi,
    I'm designing a machine and I have the mean drawing (which contains all parts) and I have one drawing for each part. To make these parts drawings, I copy each block from the mean drawing and paste it to each part drawing.
    Then, My question is: Is There a routine to update each block as the function "Ctrl+2>Redefinite"?
    I looked for a similar post and I found it but any of that post works. I've autocad 2012.
    Thanks a lot!
    Earth
    9,805
    Default Re: Update blocks for Autocad 2012
    Can you use xrefs instead of static blocks?
    Then the updating will be automatic.
    R.K. McSwain | CAD Panacea |
  1. C3D 2012 Update 1 issue
    By civil3Dguide in forum AutoCAD Civil 3D - General
    Last Post: 2011-12-13, 09:06 PM
  2. AutoCAD LT 2012 update
    By walkerj548863 in forum AutoCAD LT - General
    Last Post: 2011-10-25, 05:12 PM
  3. Autodesk Revit MEP 2012 Update 2 is now available
    By dave.pothier in forum Revit MEP - General
    Last Post: 2011-10-04, 08:34 PM
  4. AutoCAD LT 2012 - Bounding Boxes around Blocks...
    By andersonjg in forum AutoCAD LT - General
    Last Post: 2011-04-27, 03:00 PM
  5. Replies: 1
    Last Post: 2007-01-05, 01:38 AM
