Thread: 2013 Face Based Family with array issues
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,029
    Default 2013 Face Based Family with array issues
    Hi All,
    I am currently trying to get a face based family which is hosted to a reference plane to array. All things are good until I apply the array, then I get an error message (see attached image). When I host the family to a sweep it works just fine, until I change the height of the sweep/plane. Then the face based families are no longer face based. I think I'm going to try nesting the problem family into a generic face based family and setup the array there. Then nest that into my main family and link parameters as required.
    Any thoughts you could give would be helpful.
    Thank you in advance,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    986
    Default Re: 2013 Face Based Family with array issues
    If you need the array family to be hosted by any face in a project, then, the family that contains the array is the one that should be started with the face-based template. The item to repeat can be started with a generic model template.
    I could stop if I wanted to Duncan Lithgow's Avatar
    2006-09
    Denmark
    218
    we've had better results by nesting as you suggest. let us know how it works out.
    Duncan Lithgow
    Revit Support and 'agent of change'
    From New Zealand, in Denmark
    2007-09
    Madison, WI
    1,029
    Nesting of the face based family into another face based family to create the array, which was then nested into my parent family worked as expected.
    Thank you for the sanity check,
    Jeff S.
  1. Use Face Based Void Family to Cut Host Beam Family?
    By matt.fleming in forum Revit Structure - General
    Last Post: 2011-05-28, 01:53 AM
  2. Issues with face-based walls
    By arqt49 in forum Revit Architecture - General
    Last Post: 2011-03-01, 02:14 PM
  3. Face based family on curved face
    By goverholt in forum Revit MEP - Families
    Last Post: 2010-01-29, 09:38 AM
  4. Face-based Family and Annotation
    By swaddell.140874 in forum Revit Architecture - Families
    Last Post: 2009-11-13, 02:41 PM
  5. How do you changing a wall based family into a face based one
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-07-13, 05:21 AM
