Thread: convert dgn to dwg
    2015-09
    4
    Default convert dgn to dwg
    Using DGNIMPORT I have been able to convert a limited number of the Microstation/dgn files to dwg. But I get "This DGN file does not contain any models that can be imported into this drawing." on the majority of the files. Based on the file names and the message it appeared these were sheet based information. The file publisher, government entity that won't save as dwg from Microstation, confirmed that the files that will not open include all the notes, legends, sheets and titles. The files that will open are all plan type information roughly equal to what would reside in MODEL space. The files that won't open include sheet structure type information roughly equal to PAPER SPACE tabs.
    Cairo - no, not Illinois
    5,069
    Default Re: convert dgn to dwg
    best bet would be for uStn to do the conversion to dwg format. Hopefully you can get the provider of the files to provide them in a format you can use.
  1. Convert SDF to SHP
    By dkitoko in forum AutoCAD Map 3D - General
    Last Post: 2008-11-20, 03:42 AM
  2. Convert a PDF into a DWG
    By huuthu_nguyen82544 in forum AutoCAD LT - General
    Last Post: 2006-08-18, 01:02 AM
  3. Convert DWG to PCX
    By mreynolds9 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-31, 08:52 AM
  4. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
