Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Revit family Instance-Property "Stretching" stops working
  1. #11
    I could stop if I wanted to Duncan Lithgow's Avatar
    2006-09
    Denmark
    218
    Default Re: Revit family Instance-Property "Stretching" stops working
    Quote Originally Posted by jj mac View Post
    It was specifically happening with the Rotate grip. What would happen for example, if I had a workset called "Workset 1" and it was hidden (globally or overridden) in the view, the Rotate grip would be invisible.
    A rotate grip? Do you have a family where you can rotate a part of it like the hands on a clock? I'd love to have a look at that - I haven't worked out how to do that yet. Links, guides, etc welcome... !
    Duncan Lithgow
    Revit Support and 'agent of change'
    From New Zealand, in Denmark
  2. #12
    2009-02
    Toronto, ON
    173
    Sorry Duncan, I just meant the rotate icon, but I always call it the rotate "Grip"... You know, the one that pops up when you hit Rotate? You can move it around to place it where you want your axis of rotation to be? No special family.
    ___
    JJ
  3. #13
    2006-09
    Denmark
    218
    Bummer. I was getting excited ...
    Duncan Lithgow
  4. #14
    Active Member Rosie the Reviter's Avatar
    2008-07
    Chicago, IL - Milwaukee, WI
    52
    Hello all-
    Picking up where I left off, houck has it exactly right. A basic mass in a family, that is assigned an instance parameter, that has grips allowing you to pull and stretch the family ...... it very literally just stops working. Sometimes rebooting helped. Trick here is that it is hard to replicate the issue unless you are working ALL day on revit. So never really found the reason to the issue. But I agree with houck, it's most likely a memory issue.
    I have only been working in 2012, so I don't know if this issue was resolved in 2013.. one can only hope by 2014 all will be swell.. (famous last words).
    Thanks for input!
    Rosanne Siegal, LEED® AP
    Matthei & Colin Associates
    332 S. Michigan Avenue
    Chicago IL 60604
    mca-architecture.com
  5. #15
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    986
    Quote Originally Posted by houck View Post
    ... I think everyone got off track here. If you read her post, the mass stretching works for a while then just stops. ...
    Quote Originally Posted by Rosie the Reviter View Post
    ..., houck has it exactly right. A basic mass in a family, that is assigned an instance parameter, ....
    Where in the original post did anybody mention a mass? As far I understood, it was a radiant ceiling based-panel. This one can "fail' for some of the reasons that were mentioned in the previous posts. For a mass, it is different. Suppose that In a 3d view the section box is active but hidden; any mass that is stretched by pull handles beyond the faces of the section box, will seem to "lose" the ability to stretch by pull handles, and even lose the pull handles at all. If the section box is deactivated or enlarged, now the mass will be displayed as expected. Any part of the mass, including the pull handles, that was outside the box, was invisible when the section box was active or when it was too small to enclose the mass entirely.
  6. #16
    2008-07
    52
    Alfredo, you are right, it is a family, not a mass. I was using the word "mass" instead of extrusion, or form that is made in a family... I get that that would be confusing.
    Again, this issue isn't an "every-time" I use the family problem. It only occurred after having Revit open for a long time, and having used the family often in the project, so de-engineering the family and trying to get it to break that way doesn't work. The problem does happen with multiple different families, some ceiling hosted some wall hosted. Also, the parameters that break are stretching length/width, no radius etc. Grips don't disappear or gray-out, very literally they just stop working.
    Even now I can't recreate the issue, meh I'm over it. Thanks all for input, what a great network of people.
    Chicago IL 60604
  7. #17
    2007-11
    When this issue happens just tab select the edge that you want to select to get hold of the Reference Plane and then drag to to where you need it to go to.
    Not ideal, but you get over that bug.
  1. 2012: Revit "Load into Project" not working
    By Rosie the Reviter in forum Revit Architecture - Families
    Last Post: 2012-07-26, 03:22 PM
  2. Revit & "Intellectual property"
    By enslin in forum BIM Management - General
    Last Post: 2011-03-23, 05:47 PM
  3. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  4. Why "wall" concrete is a different color than "family"
    By narlee in forum Revit Architecture - General
    Last Post: 2005-11-08, 07:12 PM
