Thread: Questions from a beginner
    2009-07
    Minnesota
    41
    Default Questions from a beginner
    So I am currently in the process of teaching myself Revit, this has been a interesting undertaking. I am working on a project the has two arch beams with plates on each side there are hss's in between the arches at 30' o.c. I placed the hss's in between the arch's on the center of the beam however I need these to be attached to the plates instead of on the beam it self. The plates(these are also arched the same as the beam) were created using the model in place method so I am not able to pick the center of the plated (unless there is a way to do this that I am not aware of).
    I however believe that the intention of this program is to have the model put together the same as if it was in real life. This is my reason for attaching the hss's to the plates. My understanding of this program is some what limited and help is greatly appreciated.
    Thanks
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    Default Re: Questions from a beginner
    First, congratulations on tackling Revit, once you get the hang of it, you'll love it!
    So, you have a situation like this? (in section)
    If so, the idea is to attach the HSS to the arched beams and set the start and end extensions to put the geometry at the edge of the plate.
    If this is not your scenario, please provide a sketch so that we can understand your situation more clearly.
    Ken
    Ken Marsh
    Owner, Marsh API
  1. 2014: various questions on Revit by a beginner user
    By o.brighenti in forum Revit Architecture - General
    Last Post: 2014-06-20, 04:24 PM
  2. 2010: Some More Beginner questions
    By nybecc in forum Revit Structure - General
    Last Post: 2012-10-29, 07:30 PM
  3. 2010: More beginner Questions
    Last Post: 2012-10-19, 03:15 PM
  4. Beginner
    By minhtct in forum Revit MEP - General
    Last Post: 2011-04-27, 12:38 AM
  5. Few quick and easy questions from beginner
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-04-07, 02:15 PM
