Thread: More beginner Questions
    2009-07
    Minnesota
    41
    Default More beginner Questions
    I am in the process of modeling something that may become a project in the next year. My question is do you have to model everything right down to the gusset plates and bolts or are some of these things left out of the model and put in to the details.
    Thanks
    2011-10
    India
    37
    Default Re: More beginner Questions
    Its depending upon the Architect or your lead engineer. If arch have cut the live sections and they would like to see those stuffs, Then i would say yes.
    In most of the cases, You don't need to model them. As they will be covered in the 2D Drafting details.
    I have faced same problem in one of my project. Architect wants the haunches of the precast wall to show up in the arch model when they will link the structural model.
    So, Approach your engineer and get the feedback on how He/She wants to see this stuff. In a drafting view or actual model.
    Have a good one!
    2012-08
    14
    If you are sharing the model you may want to show them as it may effect the architects details. I haven't done that myself (quite new at this myself) but if you have revit extensions (not sure if available in 2010) then you will be able to add some connections. Otherwise you can add the 2D connection info in your detail views.
    http://aecmag.com/index.php?option=c...=313&Itemid=32
    Let me know how it goes, good luck with it.
  1. 2014: various questions on Revit by a beginner user
    By o.brighenti in forum Revit Architecture - General
    Last Post: 2014-06-20, 04:24 PM
  2. 2010: Some More Beginner questions
    By nybecc in forum Revit Structure - General
    Last Post: 2012-10-29, 07:30 PM
  3. 2010: Questions from a beginner
    Last Post: 2012-10-11, 09:19 PM
  4. Beginner
    By minhtct in forum Revit MEP - General
    Last Post: 2011-04-27, 12:38 AM
  5. Few quick and easy questions from beginner
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-04-07, 02:15 PM
