Thread: Assembly Insert Constraint and Lock Rotation
    Wish List Administration
    2011-08
    4,584
    Default Assembly Insert Constraint and Lock Rotation
    Summary: Add a Lock Rotation option to the Insert Constraint.
    Description: This would provide 1 constraint to remove all 6 degrees of freedom between 2 components. This would be especially useful for fasteners. There wouldn't be a chance of them rotating and therefore causing a change to the drawing views. You would actually be able to use the "Degrees of Freedom" display in an assembly to determine which parts are under constrained.
    Product and Feature: Inventor - API
    Submitted By: Josh Hunt on 10/12/2012
    2011-08
    4,584
    Exclamation Re: Assembly Insert Constraint and Lock Rotation
    Product and Feature: Inventor - Assemblies
    The Silent Type
    2010-07
    7
    Default Re: Assembly Insert Constraint and Lock Rotation
    I think it's what the new joint feature (R2014) does with the rotation joint.
    2012-01
    5
    Don't we have this function now with the new relationships?
    2011-08
    4,584
    2011-08
    4,584
    2011-08
    4,584
    The Silent Type Orion's Avatar
    2015-11
    Leonardtown, MD
    89
    Select part then RMB and select grounded to do this.
    Rick McNeil
    2011-08
    4,584
    2011-08
    4,584
  1. Insert constraint icon without dialog box.
    By Inventor Wishes in forum Inventor Wish List
    Last Post: 2012-12-15, 05:14 PM
  2. Mirror constraint in assembly
    Last Post: 2009-02-08, 11:28 PM
  3. Assembly Symmetry Constraint
    Last Post: 2007-06-01, 01:31 PM
  4. Highlighting a Constraint Error in an Assembly
    Last Post: 2006-04-26, 11:14 PM
  5. Lock on Constraint Selection Set
    Last Post: 2006-04-19, 04:08 AM
