Thread: Binding Xref's in ACADm2012
    2006-03
    Cedar Falls, IA
    432
    Default Binding Xref's in ACADm2012
    I have been attempting to find out how to bind Xref's into a drawing to prevent having to pack up all of the files in a folder when sharing. I do a search in the Autodesk Exchange Help and it comes up with descriptions that do not describe the step by step procedure to do this. When there is a procedure it does not apply to the version of ACAD being used. I.e. Xref Manager. How do I get the Xref Manager dialog box to appear, not to m ention the Bind Type Dialog box to appear. When I open the Xref File References box and select a referenced file to right click it and find the BIND option, it is not there. Why is it that when ever I search for something in Exchange or Help it always comes up coded and hidden deep within the definition so that only a person with 5 doctorate degrees in ACAD technology can understand? I JUST WANT TO BIND AN PDF OR IMAGE FILE WITHOUT IT BEING DEPENDENT ON THE FILE LOCATION!
    Earth
    9,541
    Default Re: Binding Xref's in ACADm2012
    Quote Originally Posted by Darren Allen View Post
    Simple answer = you can't. The DWG file format is not equipped to handle the internal definition of various image and pdf formats.
    Longer answer = you can using some alternative methods that aren't quite the same as "binding a drawing" see http://cadpanacea.com/node/65
    R.K. McSwain | CAD Panacea |
    2012-10
    Insert File as an "OLE OBJECT" works all the time. No need to Bind.
  1. Binding Xref
    By jc3cadd in forum AutoCAD General
    Last Post: 2009-10-29, 06:35 PM
  2. Xref's not binding?
    By Bobnix in forum AutoCAD General
    Last Post: 2007-04-26, 10:15 PM
  3. Bulk Xref Binding?
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2005-09-29, 02:59 PM
  4. Non binding Xref's
    By Statler in forum AutoCAD General
    Last Post: 2004-07-08, 09:10 AM
