Hi,
Here's what could be your 'Eraser' method. I also made some changes (removed unusefull statements) to the BlockTest one.
It seems to work (VB is not at all my favorite language).
Code:Private Sub Eraser() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim filter As TypedValue() = {New TypedValue(0, "INSERT"), New TypedValue(2, "Standard,Compact,Handicap,Van")} Dim psr As PromptSelectionResult = ed.SelectAll(New SelectionFilter(filter)) If psr.Status <> PromptStatus.OK Then Return End If Using doc.LockDocument() Using tr As Transaction = db.TransactionManager.StartTransaction() For Each id As ObjectId In psr.Value.GetObjectIds() Dim br As BlockReference = DirectCast(tr.GetObject(id, OpenMode.ForWrite), BlockReference) br.[Erase]() Next tr.Commit() End Using End Using End Sub Private Sub BlockTest(blockName As String) Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Using doc.LockDocument() Using tr As Transaction = db.TransactionManager.StartTransaction() Dim blockTable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) If Not blockTable.Has(blockName) Then ed.WriteMessage(vbLf & "{0} block does not exist, now inserting source file!", blockName) Dim filename As String = "C:\mkacadd_Hybrid\Civil3D\CAD data\Support\Blocks\StallCount.dwg" Dim blkId As ObjectId Using dbdwg As New Database(False, True) dbdwg.ReadDwgFile(filename, FileShare.Read, True, "") blkId = db.Insert(Path.GetFileNameWithoutExtension(filename), dbdwg, True) End Using ' Purge StallCount block Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkId, OpenMode.ForWrite), BlockTableRecord) btr.[Erase]() End If Me.Hide() Dim id As ObjectId = blockTable(blockName) Dim modelSpace As BlockTableRecord = _ DirectCast(tr.GetObject(blockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord) Dim ppo As New PromptPointOptions(vbLf & "Specify insertion point, (press ESC, SHIFT or ENTER to return): ") ppo.AllowNone = True Dim pao As New PromptAngleOptions(vbLf & "Specifiy the rotation: ") pao.UseBasePoint = True pao.DefaultValue = 0.0 pao.UseDefaultValue = True While True Dim ppr As PromptPointResult = ed.GetPoint(ppo) If ppr.Status <> PromptStatus.OK Then Exit While End If Dim pts As Point3d = ppr.Value pao.BasePoint = pts Dim pdr As PromptDoubleResult = ed.GetAngle(pao) If pdr.Status = PromptStatus.Cancel Then Exit While End If Dim angle As Double = pdr.Value Dim br As New BlockReference(pts, id) br.Rotation = angle br.TransformBy(ed.CurrentUserCoordinateSystem) modelSpace.AppendEntity(br) tr.AddNewlyCreatedDBObject(br, True) db.TransactionManager.QueueForGraphicsFlush() End While tr.Commit() End Using End Using Counter() Me.Show() End Sub
