So I have slowly gone through the process of setting up my title blocks. I have them set up with labels, custom labels and groups of the PE numbers. Now bare with me I set up the PE numbers as groups for each PE in the hopes of making it easier then setting up a title block for each PE. I have found that when I load title block into the project that being able to switch to a different PE number is not possible unless you are in the title block rfa. Which by the way makes sense. So is it possible to make the PE info into a family and insert into the sheet once it is in the project?
Also once I load the title block into the project I noticed that the custom label fields were not acting the same way the default label fields are. Meaning that with the default label I am able to change, they seem to be linked to the title block as a separate entity but my custom ones seem to be linked to the title block as if they are the same entity as the title block. I hope you guys are able to follow what I am saying.
Thanks,
Summer
