Thread: Autocad search & replace text
    2011-02
    15
    Default Autocad search & replace text
    We are moving away from using a big font and going to Arial.In the big font we typed in ~w for 3/4 stack along with all the other fractionsand symbols.
    So I was going to make a script file that would run throughthem all but I cannot get the command "find" to execute without thedialog box as this will stop the script file.
    Can you help with this maybe someone knows of another way.Basically I have multiple different search & replaces in the same drawing and the samething needs to be done in multiple drawings. I do not wish to go through multiple sheets searching and replacing each
    Your help would be greatly appreciated.
    Mark
    2012-11
    Default Re: Autocad search & replace text
    try select all then modify click text then change the font and size u desired.
  1. Enhanced Search and Replace options
    Last Post: 2013-11-15, 08:01 AM
  2. Search for Text in AutoCAD File
    Last Post: 2010-03-15, 11:25 AM
  3. Search and Replace
    By GreenMan415 in forum Dot Net API
    Last Post: 2009-12-04, 06:41 PM
  4. Text search and replace
    Last Post: 2008-12-23, 03:06 PM
  5. Text search and replace routine across multiple drawing files
    By David van Erk in forum AutoCAD Customization
    Last Post: 2006-05-19, 10:31 PM
