Thread: edit family - simple question...yes or no?
    2012-10
    Default edit family - simple question...yes or no?
    Hi at all,
    can i modify a family and its parameters in a project document with revit API without enter the family editor?
    I tried to search but nothing,
    thanks
    I could stop if I wanted to USMCBody's Avatar
    2008-05
    Bristol, PA
    240
    Default Re: edit family - simple question...yes or no?
    basically it depends if the family was made to do that or not... Not sure what else to say???
    Easy as Eating Pancakes.
    -Space: Above and Beyond
    2008-12
    69
    You can assign Values (Modify) to any Param (Type or Instance, Building or System Component) from a Project. What are you trying to do?
    2012-10
    i'm trying to change value of a family type parameter in project document but it doesn't work. I was able to modify only family instance parameters
    2012-10
    ok i resolve...thank you I post the code as soon as
  1. simple uv question
    By morgule725263 in forum 3ds Max - General
    Last Post: 2011-10-11, 01:01 PM
  2. Question simple...
    By Pascal.Parent2 in forum Revit Architecture - Général
    Last Post: 2009-01-13, 01:00 PM
  3. Simple Question, again
    By BeKirra in forum AutoLISP
    Last Post: 2008-11-23, 08:32 PM
  4. Simple question about changing a linetype on a family
    By Matt Mercer in forum Revit Architecture - Families
    Last Post: 2005-10-07, 02:22 AM
  5. Simple question about changing a linetype on a family
    By Matt Mercer in forum Revit Architecture - General
