Thread: Text on wrong layer
    2007-03
    8
    Default Text on wrong layer
    Autocad MEP 2013
    I have just started using 2013 and have noticed that when I label a circuit, the text goes on the current layer instead of the layer it should.
    I have not had this problem with 2010, (didn't use 2011 or 2012, they didn't work with my modifications). Am I doing something wrong or is it a quirk in 2013?
    2008-03
    32
    Default Re: Text on wrong layer
    Sounds similar to my recent issue (referring to MEP 2013 layer key styles post a while back) - anyways - My issue was fixed when I installed the new patch. Have you installed the new patch?
    2007-03
    8
    Quote Originally Posted by jparkhurst View Post
    I installed the latest update-no glory. Is this the patch you were speaking of?
    2008-03
    32
    Yeah - that'd be the one - Not sure what else to suggest other than to make sure your layer key style is assigned in the drawing but I suspect you've already done that.
  1. 2014: Wrong Layer Property Manager?
    By nelson in forum AutoCAD Civil 3D - General
    Last Post: 2014-06-16, 08:46 PM
  2. Air Terminal Tag on Wrong Layer
    By taliesyn.102216 in forum AMEP General
    Last Post: 2009-01-26, 04:38 PM
  3. text orientation wrong in text editor
    By rickfennell.153918 in forum AutoCAD General
    Last Post: 2007-12-19, 08:14 PM
  4. blocks inserting on wrong layer
    By crbickel in forum ACA General
    Last Post: 2007-09-13, 08:14 PM
  5. Survey Figures same name wrong layer
    By KansasCAD in forum AutoCAD Civil 3D - General
    Last Post: 2007-06-27, 12:57 PM
