Results 1 to 7 of 7
Thread: Network License - Send an offsite person a license?
    2005-10
    Boston, MA
    74
    Exclamation Network License - Send an offsite person a license?
    One of our guys had to fly to a jobsite in another state. He will be there for several days, and he forgot to borrow a license from our network license utility before he went. We use LM Tools.
    Is there any way to send him a license?
    - Jon
    2015-10
    Irvine, CA
    113
    Default Re: Network License - Send an offsite person a license?
    If your office has VPN set up, you can have him connect to that. Once connected, he should be able to get his license as long as the server that hosts the licesning is available through the VPN. One thing you might have to do is have the user navigate to the server manually to establisha a connection. They might get a pop-up asking them to locate the license file, thats where you would navigate to the server or the license file itself. Hopefully this helps. Post any questions.
    2015-11
    Madison, WI
    1,318
    Jon,
    Is it possible for your co-worker to connect to a workstation within the office via Remote Desktop Connect to do his work? This would require a VPN or similar access to your network.
    Cheers,
    Jeff S.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Like Devin said, VPN...what helps is locating the logon script on your domain server once connected via VPN...so that it will create all the mapped drives, and then Revit will find the license without one having to search for it manually.
    Then they can borrow the license for the duration.
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    2005-10
    Boston, MA
    74
    @ Devin & cdatech guy, thanks for the tip, our IT guys are working on setting up VPN for him.
    @ Jeff, we do use GoToMyPC for that, but the jobsite doesn't have internet. His hotel room does, so i think we will go with the VPN idea, and get him to borrow for the duration.
    Thanks everyone. Not an "easy" solution, but still beats not having the ability to work while he is there.
    2005-10
    Boston, MA
    74
    Quick aside, is there such a thing as a cloud based autodesk license server? I am just wondering if it exists, and if so does anyone use it successfully. It might be cool if something like this exists so that users could connect to a license only needing an internet connection.
    I could stop if I wanted to bbeck's Avatar
    2016-01
    Sacramento, CA
    247
    Quote Originally Posted by jontramos View Post
    Citrix is the only virtual environment that Autodesk officially supports. So, yes, if you were to have a Citrix based server with Citrix Autodesk licenses you would be ok. Other cloud solutions exist, however, the ELUA is an ever evolving animal that changes with each release. VPN back to your license server is the most straight forward solution (for licenses).
  1. 2009 license transfer with PLU - license type: standalone - locked
    By Mauri12345 in forum AutoCAD Mechanical - General
    Last Post: 2014-04-02, 12:07 PM
  2. Network license issue
    By SupremeTaco in forum Revit Architecture - General
    Last Post: 2009-01-21, 05:05 PM
  3. Network License Error
    By trythefly in forum AMEP General
    Last Post: 2007-08-01, 04:31 PM
  4. Network License : So expensive?
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2006-05-16, 09:59 PM
  5. Network license for 2005
    By vlee in forum AutoCAD General
    Last Post: 2004-07-05, 06:21 PM
