Thread: Top Rails Revit 2013
    2012-10
    Default Top Rails Revit 2013
    Is there a problem with the new feature in revit 2013 using the top rails as handrails?
    if i model a top rail with 36" aff and 1 1/2" dia and use say floor extension 12" long, it models it but won't show in plan. if i hover over where it should be it then hightlights. if i change the top rail to a regular hand rail then it shows up. what am i missing with this new feature?
    this may help...
    top rail feature and highlights while editing
    now it doesn't show
    if i hover over it with the mouse it shows and selects
    shown in section it is there
    why won't is show in plan?
    2012-06
    Minnesota
    51
    Default Re: Top Rails Revit 2013
    It might have to do with your view range. Not sure, but maybe try messing with that.
    2012-10
    i have tried that. if i change the top rail to the way handrails and guardrails were modeled in 2012 and earlier, then it shows up. i was really excited about this feature becuase it has handrail wall extensions returns, floor returns and the P return built into it but you have to use it with a top rail function which i can't get to seem to display....
    2004-05
    St. Louis, Missouri
    3,135
    Try using a Plan Region, and set the View Range differently than the rest of the Floor Plan View and see it it will display. If it displays in elevation/section/3D, then it is a visibility issue in the Plan.
    2012-10
    so i figured it out by accident. they are not visible in a coarse view setting, only medium and fine. this has been driving me nuts. regualr rails do not do that!
  1. Exportar Revit 2012-2013 a 3ds Max Design 2013...
    By magdagarciavinuesa in forum Revit Architecture - General
    Last Post: 2015-02-04, 10:34 PM
  2. 2013 Objects From Revit MEP 2013 Missing in Navis Manage 2013
    By MetalliCAD in forum NavisWorks - General
    Last Post: 2013-03-05, 08:52 PM
  3. Revit 2013 Detail Views Showing up in Navisworks 2013
    By tfullerpipes in forum NavisWorks - General
    Last Post: 2013-01-30, 07:37 AM
  4. 2013 Revit 2013 to navisworks Manage 2013
    By markclarenzze in forum NavisWorks - General
    Last Post: 2013-01-14, 10:02 AM
  5. Revit DB Link 2013 and Access 2013?
    By KELLI in forum Revit Architecture - General
    Last Post: 2012-11-20, 04:29 PM
