I just noticed in 2013 if I have an RCP view with a split crop region, and the crop regions moved closer in to each other, that part of the ceiling pattern in one of the regions partially disappears! The missing pattern increases as you move one region closer to the other. This is 2013 with Update 2 installed.
Anyone else noticed this?
*edit* Graphic bug for sure. I can still snap things to the pattern lines even though they are not visible, and thankfully the pattern lines do print correctly.
