I changed the slope angle of a sloped glazing roof. All the curtain grids and mullions were deleted. There is certainly a simple way of preventing this from happening, but how is it done?
I believe this problem occurs when you change the pitch of sloped glazing, because some curtain grids on a panel are no longer meeting exactly at a point, creating a small triangular panel within the main panel; the triangular panel cannot be accurately regenerated because it is too small.
I don’t think there is a work-around for this. It is necessary to delete the offending mullions using the error dialogue and then recreate them
Which takes one click with the mullion tool set to 'all empty segements', so not really so bad.to delete the offending mullions using the error dialogue and then recreate them
Thanks for the replies. The solution occurred to be not to have the detail level set at "fine" when changing the angle.With detail level at "medium " or "coarse" the problem did not show up.
