Results 1 to 10 of 10
Thread: dt changes the layer setting
    2005-01
    Columbus, IN
    23
    Default dt changes the layer setting
    When typing in dt(dtext) it changes the layer that I have set to a layer named s_layer. How do I fix this?
    0,0,0 The Origin
    8,024
    Default Re: dt changes the layer setting
    Quote Originally Posted by bryanf View Post
    Someone has created a lisp (or other) routine called "DT". To confirm, try typing ".dt" (without quotes) - it should run the standard command.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by jaberwok View Post
    not necessarily, there could be a reactor firing when the dtext command is called that changes the layer. at our office we dont have one for dtext, but we do for dimensions, it switches to our standard dimension layer.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    Houston
    7,519
    Does it do the same thing if you type in the command .Text ? (note the leading period)
    2005-01
    Columbus, IN
    23
    No it does not do the same thing, I have even tried to change the command allias but that didn't work either.
    Cairo - no, not Illinois
    2,714
    type in !C:DT
    what's the response?
    Officially Awesome
    2005-01
    Columbus, IN
    23
    #<SUBR @ 0000000037802cf0 C:DT> is what was returned
    2,714
    OK, that tells me that jaberwok was correct, and that the DT command has been redefined via LISP. Somewhere on your support path is a .lsp, .vlx, .fas, or .mnl file that is defining the command to include the layer change.
    Happy hunting!
    If all your paths are indexed, you can use Windows 7 search to look for it -- search on defun c:dt and see what you find
    Officially Awesome
    0,0,0 The Origin
    8,024
    Did you try .DT (with leading period/point) ?
    John B
    2009-06
    Toowoomba, QLD, Aus
    56
    Is this S_LAYER a part of the drafting standard within the office?
    Surely the DT command being redefined via LISP has been done for a reason, Maybe the CAD manager set it up like that to force everyone to comply with a layer naming standard.
  1. DWG export layer setting
    By ktsnguyenhoanghieu in forum Revit Architecture - General
    Last Post: 2009-08-07, 04:17 PM
  2. Setting Layer Keystyle thru VBA
    By ccastelein in forum VBA/COM Interop
    Last Post: 2008-09-25, 03:02 PM
  3. Setting Layer Filters
    By bjlottis in forum AutoCAD General
    Last Post: 2005-04-18, 06:21 PM
  4. Dimension layer setting
    By stanmccall in forum AutoCAD Customization
    Last Post: 2004-06-21, 07:15 PM
