Thread: Text showing different heights on BOLD
    2012-08
    7
    Question Text showing different heights on BOLD
    OK,
    so perhaps I'm having a blonde moment, but I can't figure this out...
    I have 2 text styles:
    Arial Narrow 2.5mm
    Arial Narrow 2.5mm BOLD
    for some reason the BOLD version is showing as though it is only 2.0mm text?
    I have attached the example. You can get the same effect simply by checking the BOLD box on the standard 2.5mm text - it will get smaller!!
    This is baffling and annoying, I am currently having to use a text of 3.0mm BOLD to get actual 2.5mm BOLD text...
    Any clues?
    AUGI Addict cdatechguy's Avatar
    2004-02
    CdA, ID
    1,371
    Default Re: Text showing different heights on BOLD
    They show the same size on my screen...
    Michael "MP" Patrick
    "I never make stupid mistakes. Only very, very clever ones."
    2012-08
    7
    That is strange.
    Attached (i hope) a screen shot of that rvt file i attached earlier. They are not the same size on my machine? nor do they print the same height?
    2012-08
    7
    and again more images...
    these are the settings for each of the text's.
  1. 2013: How to Remove BOLD from within Text notes?
    By ddraynor in forum Revit Architecture - General
    Last Post: 2012-09-24, 01:42 PM
  2. Change Text to Bold
    By dhf000 in forum AutoCAD General
    Last Post: 2009-07-30, 06:57 PM
  3. Italic / Bold Text
    By jonathanm in forum Revit MEP - General
    Last Post: 2009-05-08, 02:46 PM
  4. Dimension text with Arial Bold
    By Henry D in forum Revit Architecture - General
    Last Post: 2006-12-17, 07:27 PM
  5. AutoCAD 2007 - DWG to PDF causes my Text to look bold
    By pangell in forum AutoCAD Plotting
    Last Post: 2006-06-12, 09:05 PM
