Thread: Pipe Fitting Radius Multiplier
    2012-04
    Green Bay, WI
    29
    Default Pipe Fitting Radius Multiplier
    Does anyone know if there is a way to specify the radius of a pipe elbow, similar to radius multiplier used in the duct fittings? If not, how do you manually specify the turning radius of a pipe elbow? The generic pipe elbow has almost no radius.
    Thank you in advance
    2012-04
    Green Bay, WI
    29
    Default Re: Pipe Fitting Radius Multiplier
    Nevermind, found it. changed the Center Radius Parameter equation to 1.5*Nominal Diameter. It was in front of me the whole time. Guess it's been awhile since I used Revit
    2015-08
    Could you please describe how you changed the equation? Where is the equation? I am using 2015. Thanks
    2015-09
    4
    Navigate to the Family Category and Parameters dialog box and look under the formula column of the parameter called Center Radius.
  1. 2013: Cable Tray Fitting bend default radius
    By ftonelli in forum Revit MEP - Families
    Last Post: 2017-10-13, 09:40 AM
  2. 2013: Pipe fitting - bend radius
    By desandli836892 in forum Revit MEP - Families
    Last Post: 2013-02-19, 01:39 PM
  3. Pipe fitting - fixed radius
    By bb1 in forum Revit MEP - General
    Last Post: 2011-02-05, 04:33 PM
  4. Reducing Pipe Fitting Sizing Issue Based on Pipe Size
    By cdsuggs in forum Revit MEP - Families
    Last Post: 2010-07-22, 08:06 PM
  5. Long Radius Pipe Fitting
    By rafterman in forum Revit MEP - General
    Last Post: 2006-07-20, 07:12 PM
Tags for this Thread
