Thread: LINE AND CURVE TABLES
    2004-06
    Slidell, Louisiana
    972
    Default LINE AND CURVE TABLES
    I've search the forum for info and have seen some people having problems with this feature.
    I am having a MAJOR issue with it. It just doesn't play well with others is the best way I can put it.
    If you change a table parameter, i.e. spacing and select force realignment, sometimes it works, sometimes it doesn't.
    have regened, changed across and down, row numbers just about everything I can. still not going back to the right way.
    seems like you have to have it set exactly how you want it to appear the very first time.
    is anyone else having this type of issue?
    thanks.
    5,719
    Default Re: LINE AND CURVE TABLES
    I too am admittedly having trouble with Curve Tables as well - however my issue(s) seem to be more about not being able to combine Alignment, and Parcel Curve Tables, etc. (currently having to do them separate, which is not how my employer depicts them historically). Grrr
    2014-08
    447
    thats why I get them close then explode and manually edit them. it's a painful reality of Civil3D.
    5,719
    Quote Originally Posted by remi678731 View Post
    Regretfully one of my own observations in using Civil 3D, and for more than just *Curve Tables - I end up slowing production by using myriad DREFs, etc. or multiple drawings as I'll work in a Civil 3D model (Existing Surface to show contours and label, as example), and then end up exporting to AutoCAD for a 'dumb' linework XREF which greatly increases performance of opening and printing sheet drawings... I just really cannot stand the duplication of work, either. Grrr
    2004-06
    Slidell, Louisiana
    972
    If you explode them and manually edit them, don't you lose all the dynamic ability of the software?
    Also, in a line table, where & what style do you modify to change the parameters of the bearing and distances, i.e. distances to 2 decimal places with a foot mark and bearings to the nearest second.
    is the tag style or some other, I can't find where to change it.
    also, in a table with delta, I can't get the style to display degrees, minutes, seconds.
    after much digging, I finally found where to change them.
    5,719
    Quote Originally Posted by rmk View Post
    Correct.
    Presumably you found that to modify the Curve Table's output, you simply modify the Curve Table's Style.
    Cheers
  1. Curve Tables
    By hruiz in forum AutoCAD Civil 3D - General
    Last Post: 2009-08-11, 03:50 PM
  2. Curve Tables
    By smooth shoes in forum AutoCAD General
    Last Post: 2008-06-30, 12:06 PM
  3. line and curve tables not from parcels
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-04-02, 12:30 PM
