Could someone explain to me what this message means. It a appears on occasion when I try to insert a certain Tblk. into a dwg. That is probably the cause of the problem, but I can still get it to insert after I save it as a different dwg. name.
Hi djahnke
Please note I moved this thread from the AutoCAD 2005 General forum to this one, as I believe it would be better served here.
It looks like you might have something classified in your titleblock that is using the same name as a classification in the host drawing.
If you that ain't it, post your drawing so we can have a look at it.
Does your Titleblock have attributes in it that are associated to a Database? Have you updated the values in the DB and not the Tb, or vice-versa? Or has someone set up classes for the attributes?
Well there is nothing within the drawing that re-associates itself to a database, but the dwg. is located in what we call our dwg. database on our server.
Are you Inserting the TBlk or Xreffing it into your drawings? Is the filename the Database Key? If so, you cannot have two Keys with the same name in a DB.
