Results 1 to 6 of 6
Thread: Text Editor
    Wish List Administration
    2011-08
    4,584
    Default Text Editor
    Summary: Revit needs a more robust text editor
    Description: Revit needs a more robust text editor, similar to what Auto cad has now
    This is needs for General notes, Legends, etc.
    Currently our Office standard is to create notes in Autocad and link them into Revit because of Revit's Text editor limitations (i.e. indenting, numbering and/or Bullet points, etc...)
    Product and Feature: Revit Architecture - Annotation Tools
    Submitted By: John Blasquez on 11/13/2012
    2015-09
    10
    1 members found this post helpful.
    Cool Re: Text Editor
    We use keyed schedules for our notes. Simply start a quantity schedule, I prefer doors, and select schedule keys radio button on the right side of the dalouge box. You only need two parameters for number and text. We hide the headers and the grids. The rest can be picked up as you work with it.
    This has worked well for notes as it remains native to Revit, can go on any sheet and is instantly update-able.
    There are some minor drawbacks such that editing long lines of text can get cumbersome and any adjustment to the keyed schedule size on one sheet is propagated to all other instances of the notes. Both of these are quite minor and have not stopped us from using it as notes.
    That being said, I agree with the wish, it would be nice.
    2012-07
    2
    Default Re: Text Editor
    Revit needs to Fix it's text editor. the current alphabet soup & unstable text format behavior is unacceptable. this has been a Known issue for over 5 releases now.
    2011-04
    88
    @ reckstein448180 that's a great solution... to a completely different problem
    2011-04
    88
    Thumbs up Re: Text Editor
    As bearsley138506 mentioned, the way Revit randomly resizes the text when editing a textbox at different zoom levels is frustrating for users and can produce inconsistent documentation results. Revit's text editing features are weak at best, comparable to Notepad circa Windows 95, it should be far more extensive by now. It ought to offer full formatting options, such as Case changing, Indents, Styles (like Office for consistent drafting standards), Shadow-masking, Colour-masking-right-to-borders, support for OpenType Postcript fonts, and enhanced Find and Replace (searching View names, wildcards and multiple-lines).
    2009-07
    2
    Agree with all of the above, I'd also like to have more options with leaders. Curved leaders with left aligned text are graphically very messy. Minor but frustrating.
  1. 2011: ACA2011-Text editor appears on top of text? Help!!
    By cadlivin in forum AutoCAD General
    Last Post: 2014-07-01, 02:49 AM
  2. changing text height inside text component editor
    By smcgypsea in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-04-29, 11:44 AM
  3. Dimension text editor, text appears tiny
    By Clarence Worley in forum AutoCAD General
    Last Post: 2007-06-13, 03:46 PM
  4. Multiline Text Editor truncating imported text file
    By zellingj in forum AutoCAD General
    Last Post: 2006-12-06, 10:28 PM
  5. The ability to cut & paste text in the text editor
    By pwhite in forum Revit Architecture - General
    Last Post: 2005-09-28, 04:11 PM
