Thread: Creating non-mirrorable Revit Families
    2012-09
    Default Creating non-mirrorable Revit Families
    Hi, I'm not sure if it's just my lack of terminology or the fact that searching for "mirror" or "mirrored" tends to give me families of mirror objects but my question is this:
    I have equipment families that I'm creating that should never be mirrored. This is the way they are manufactured, and they cannot created one with an access panel opening on the other side.
    Do I use the single controls, or is there another way of ensuring the family can never be mirrored when inserted into a drawing?
    2001-07
    Phoenix, AZ
    1,003
    Default Re: Creating non-mirrorable Revit Families
    You can't keep someone from mirroring the family with the mirror command. I think you're going to have to educate the end user another way.
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,310
    If you place Model Text in the family, when it gets mirrored it will be an indicator to the user that they shouldn't have mirrored it. I tell all my end users not to mirror most of the equipment we design around. Some listen some don't...
    Cheers,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    809
    Heather - there is no way you can stop users from mirroring your families...but if it helps, you can download the AutoDesk Revit Model Review (free within your subscription centre) and set it up so it reports if a component has been mirrored - it will give you the ID of the object so you can find it and mirror it back
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
  1. Creating Revit Families
    By sthom in forum ATP Course Wishlist
    Last Post: 2008-11-26, 04:39 PM
  2. Creating Symbols for Families
    By jeffsr in forum Revit MEP - Families
    Last Post: 2006-12-14, 03:30 AM
  3. Creating Double Door Families in Revit that can move in Max
    By jlutz.102978 in forum Revit Architecture - General
    Last Post: 2006-09-05, 11:06 PM
  4. New Augi World Magazine "Creating Revit Families"
    By Scott Davis in forum Revit Architecture - Families
    Last Post: 2004-02-05, 03:58 PM
  5. Creating Families
    By Revitlution in forum Revit Architecture - Families
    Last Post: 2003-10-10, 09:59 PM
