Thread: Sloping Gutters
    2008-05
    Brisbane, Australia
    9
    Question Sloping Gutters
    I know this problem has come up a little as I've done some extensive searching. Sadly I've failed to find an answer that is somewhat straight forward. It really doesn't seem like it should be an issue for a program with such power.
    as you can see from the first picture "raw roof". This is what I'm trying to put the gutter on. The second picture shows the issue I'm having of the gutter not connecting correctly in the corner.
    command i have use to attach the gutter is as follows
    Roof > Roof : Fascia > gutter & fascia > then selected the roof's edge.
    Is there a simple work around or something simple that I'm missing? any help is greatly appreciated.
    All AUGI, all the time gbrowne's Avatar
    2004-03
    Glasgow, Scotland
    579
    Default Re: Sloping Gutters
    If I understand how you've created that, you're trying to combine a gutter profile to a fascia profile? I swapped out my default fascia profile for the same profile as the gutter and tried it, and it worked.
    I do have to ask, would you actually construct the roof/gutter like this? The water is going to just pour off this roof and straight out of the gutter, no?
  1. Gutters
    By csmith.152384 in forum Revit - Platform
    Last Post: 2010-08-29, 03:28 PM
  2. gutters
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-07-21, 08:32 PM
  3. gutters
    By jwenzeljr in forum Revit Architecture - General
    Last Post: 2010-06-25, 06:59 AM
  4. Joining curved sloping roof to curved sloping wall
    By Chetan.b in forum Revit Architecture - General
    Last Post: 2008-03-26, 01:40 PM
  5. Sloping Floor / Sloping Trench Drain
    By Knoll in forum Revit Architecture - Families
    Last Post: 2006-02-26, 09:00 PM
Tags for this Thread
