Hey All,
Fixo, in his mastery, had helped a fellow user create a table of attributes here. This is EXACTLY what I'm looking for, but... it doesn't seem to work with dynamic blocks. Is there something that can easily be done to modify code to work with DBs?
Code by Fixo:
(defun C:PARTREF3(/ acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
column colwidth datalist en headers pt row sset swap tabledata tags total txtheight widths x)
;private function
(defun sum-and-groupby-three (lst / groups res sum tmp)
(while lst
(setq tmp (car lst)
sum
(apply '+
(mapcar 'atoi (mapcar 'cdadr
(setq res (vl-remove-if-not
'(lambda (a) (and
(eq (cdr (nth 0 a)) (cdr (nth 0 tmp)))
(eq (cdr (nth 1 a)) (cdr (nth 1 tmp)))
(eq (cdr (nth 2 a)) (cdr (nth 2 tmp)))))
lst
groups (cons (subst (cons "QTY" (itoa sum))(cadr tmp) tmp) groups)
lst
(vl-remove-if
'(lambda (a) (member a res))
lst
(reverse groups)
;private function
(defun sum-and-groupby (lst / count countdata elem match tmp)
(while lst
(setq tmp (car lst))
(setq match (vl-remove-if-not '(lambda(x)(and (eq (cdr (nth 0 x))(cdr (nth 0 tmp) ))
(eq (cdr (nth 2 x))(cdr (nth 2 tmp) ))
(eq (cdr (nth 3 x))(cdr (nth 3 tmp) ))))
lst))
(setq count (apply '+ (mapcar 'atoi (mapcar 'cdr (mapcar 'cadr match)))))
(setq elem (list (cdr (nth 0 tmp))
(itoa count)
(cdr (nth 2 tmp))
(cdr (nth 3 tmp))
(cdr (nth 4 tmp))))
(setq countdata (cons elem countdata))
(setq lst (vl-remove-if '(lambda(x)(and (eq (cdr (nth 0 x))(cdr (nth 0 tmp) ))
lst))
(vl-sort countdata '(lambda(a b)(< (car a)(car b))))
; main part ;
(if (setq sset (ssget (list (cons 0 "INSERT") (cons 66 1))))
(progn
(setq tabledata nil
attdata nil
attitem nil
(while (setq en (ssname sset 0))
(setq blkobj (vlax-ename->vla-object en)
blkname (vla-get-effectivename blkobj)
(setq atts (vlax-invoke blkobj 'getattributes))
(foreach attobj atts
(setq attitem (cons (vla-get-tagstring attobj) (vla-get-textstring attobj)))
(setq attdata (cons attitem attdata))
(setq tabledata (cons (reverse attdata) tabledata))
(setq attdata nil
attitem nil
(ssdel en sset)
(setq headers (mapcar 'car (car tabledata))
tags headers
(setq tabledata (sum-and-groupby-three tabledata))
(setq tabledata (sum-and-groupby tabledata))
;; sort by "PART-REF" :
(setq total 0)
(foreach i datalist (setq total (+ total (cdr i))))
(initget 6)
(setq txtheight (getreal "\nSpecify Text height for the table <50>:"))
(cond ((not txtheight)(setq txtheight 50))) ;<-- text height as for as in your drawing
(or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))))
(or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))))
(setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa(atoi(getvar "acadver"))))))
(setq pt (getpoint "\nSpecify table location:"))
(setq atable (vla-addtable
acsp
(vlax-3d-point pt)
(+ 2 (length tabledata))
(length headers)
(* txtheight 1.2)
(* txtheight 20)
(vla-put-regeneratetablesuppressed atable :vlax-true)
;; calculate column widths :
(setq swap (append (list headers) tabledata)
widths nil)
(while (car swap)
(setq column (mapcar 'car swap))
(setq colwidth (* 1.2 (apply 'max (mapcar 'strlen column))txtheight))
(setq widths (cons colwidth widths))
(setq swap (mapcar 'cdr swap)))
(setq widths (reverse widths))
;; set column widths
(setq col 0)
(foreach wid widths
(vla-setcolumnwidth atable col wid)
(setq col (1+ col))
(vla-put-horzcellmargin atable (* txtheight 0.5))
(vla-put-vertcellmargin atable (* txtheight 0.3))
(vla-setTextheight atable 1 txtheight)
(vla-setTextheight atable 2 txtheight)
(vla-setTextheight atable 4 txtheight)
(vla-setText atable 0 0 "PART SUMMARY")
(vla-SetCellAlignment atable 0 0 acMiddleCenter)
(vla-put-colorindex accol 2)
(vla-setcellcontentcolor atable 0 0 accol)
(setq col -1)
(foreach descr headers
(vla-setText atable 1 (setq col (1+ col)) descr)
(vla-SetCellAlignment atable 1 col acMiddleCenter)
(vla-setcellcontentcolor atable 1 col accol)
(vla-put-colorindex accol 4)
(setq row 2)
(foreach record tabledata
(setq col 0)
(foreach item record
(vla-setText atable row col item)
(if (= 1 col)
(vla-SetCellAlignment atable row col acMiddleCenter)
(vla-SetCellAlignment atable row col acMiddleLeft)
(vla-setcellcontentcolor atable row col accol)
(setq col (1+ col))
(setq row (1+ row))
(vla-put-width atable (apply '+ widths))
(vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight))
(vla-put-regeneratetablesuppressed atable :vlax-false)
(if accol (vlax-release-object accol))
(if acapp (vlax-release-object acapp))
(prompt "\n\t---\tStart command with PARTREF3\t---\n")
(prin1)
(or (vl-load-com))
Thanks for taking a look,
-stu
