This is more than likely a simple fix that is eluding me. I want to show the outer diameter of the pipe in plan but not the inner. I have already created the network. Is this a style setting somewhere that controls this?
Could you please share the answer on the forums. It may be helpful to others. Thanks.
In the style you have several different lines you can control for the display of a pipe they are as follows:
Plan - Center, Inner, Outer, End, Hatch
Profile - Center, Inner, Outer, End, Hatch, Crossing Inner, Crossing Outer
Cross Section - Inner, Outer, Hatch
Model - Solid
You can turn each of these off and on. It is best to have a style setup for each way you might display a style in your template so you can override as needed in the profiles and sections the way you want them diplayed. This way you can have multiple alignments, multiple pipes, and multiple section groups, but can apply different styles with having 1 style applied in the plan view.
