Thread: Command and Macro
    2012-09
    Question Command and Macro
    hi, I need to find the command that allow you to change your cursor in 45 degree. I also need to know the macro of this command ?
    Thanks !
    0,0,0 The Origin
    8,060
    Default Re: Command and Macro
    Quote Originally Posted by fat_max88477597 View Post
    Thanks !
    I guess you mean -
    snapang
    45
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    100 Club jseck's Avatar
    2009-06
    Missouri
    111
    I have the following in my acad.lsp file...
    ;;===================SHORTCUT COMMANDS============================
    (defun C:0()(command "SNAPANG" 0))
    (defun C:45()(command "SNAPANG" 45))
    (defun C:30()(command "SNAPANG" 30))
    (defun C:60()(command "SNAPANG" 60))
    2006-05
    5
    I use a lisp routine called RCH.lsp. I found it on the Internet and use it extensively. Thanks to whom ever wrote it. I do not take credit for it ...
    (prompt "\n...RCH loaded. Type RCH to start.......")
    (defun C:RCH (/ r e p1 p2)
    (graphscr)
    (initget "Entity")
    (setq r
    (getangle "\nSnap rotation angle/<Entity>: "))
    (cond
    ( (numberp r)
    (setvar "snapang" r))
    ( (and (or (not r) (eq r "Entity"))
    (setq e (entsel))
    (setq p1 (osnap (cadr e) "qui,end"))
    (setq p2 (osnap (cadr e) "qui,mid")))
    (setvar "snapang" (angle p1 p2)))
    (t (princ "\nInvalid selection.")))
    Active Member Brian C's Avatar
    2008-08
    Vancouver, BC
    85
    One must remember that SNAPANG only works with your ortho turned on. If polar tracking is set, ortho turns off, but the cursor still turns at the specified SNAPANG, but does not snap to it. I prefer using polar tracking and setting the POLARANG variable.
    Brian C
    "The difference is my flaws are personal. Yours are professional." [Col. Tigh, BSG 2004]
  1. creating a macro/command button?
    By neil.hughes in forum AutoLISP
    Last Post: 2009-12-02, 06:17 PM
  2. Loading a script from a command macro
    By ewhite in forum AutoCAD Customization
    Last Post: 2007-04-08, 04:44 AM
  3. Command macro in Image Menu
    By sifuentes in forum AutoCAD Customization
    Last Post: 2006-05-24, 10:17 PM
  4. Multiple command macro within pulldown menu
    By louis.64641 in forum AutoCAD Customization
    Last Post: 2006-04-04, 09:43 PM
  5. Use CHANGE command inside a macro
    By lhunt in forum AutoCAD Customization
    Last Post: 2006-03-10, 10:29 PM
