Results 1 to 10 of 15
Thread: Worksharing Problems - Central Model Not Accessible
    All AUGI, all the time TerribleTim's Avatar
    2006-03
    Tacoma, Wa
    639
    Default Worksharing Problems - Central Model Not Accessible
    Ok guys, I just ran into this one and can't find an answer.
    I've got a central model with local models on a couple machines. One of my users gets a message when opening his local model that "The Central Model Is Not Accessible. Re-open Using Detatch From Central." Umm, I don't want it detatched. How do I fix this? I thought I could just delete his local model and create a new local model, but that didn't work.
    HELP!!!!!!!
    Tim McDougald
    BIM Coordinator / Project Manager
    Clevenger Associates
    11803 101st Avenue Court East, Suite 203 - Puyallup, Washington 98373
    HayWire Racing
    1101 124th Street South, Suite B - Tacoma, Washington 98444
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Worksharing Problems - Central Model Not Accessible
    First, check that user's connection to the network ( cmd ipconfig /flushdns and renew ).
    2nd, see if that user can open any other workshared project from the server--if so, it is something project-specific.
    3rd, try changing the user's Revit user name in Options, and try opening Central and creating new local. I have seen a Windows User Profile sometimes casue problems as well.
    4th, try deleting the user's .tmp files on his C: drive, then try again.
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2006-03
    Tacoma, Wa
    639
    Cliff, many thanks for the prompt reply. Here are the answers to your questions.
    Quote Originally Posted by cliff collins View Post
    First, check that user's connection to the network ( cmd ipconfig /flushdns and renew )...
    Network connection is not the issue. Confirmed working fine since he is working on other stuff across the network in the mean time.
    ...2nd, see if that user can open any other workshared project from the server--if so, it is something project-specific...
    Not project specific, does this with all projects.
    ...3rd, try changing the user's Revit user name in Options, and try opening Central and creating new local. I have seen a Windows User Profile sometimes casue problems as well...
    Tried that, same problem.
    ...4th, try deleting the user's .tmp files on his C: drive, then try again.
    Where do I find that? I know where Revit stores the local model and the backup files for that model but am not sure where the .tmp files reside.
    Tim McDougald
    HayWire Racing
    I could stop if I wanted to rbcameron1's Avatar
    2008-09
    Nebraska & Iowa
    378
    Open up windows explorer, right click on the OS C:/ drive and do a disk cleanup. When the disk cleanup manager pops up make sure to click the checkbox next to "Temporary Files". click ok.
    RB Cameron, AIA, LEED AP, EDAC
    BIM Coordinator - VDC Coordinator - Visualization Artist
    Download Healthcare Revit+3dsMax Models
    Download Revit+3dsMax Models
    2004-05
    St. Louis, Missouri
    3,135
    search C: for *.tmp.
    St. Louis, MO
    2006-03
    Tacoma, Wa
    639
    Did that, still have same issue. I'm thinking the next step will be to just detatch, then create a new central from that file. But I see a lot of posts where that has only solved the problem until the next time that computer gets turned off and turned back on.
    Tim McDougald
    HayWire Racing
    2004-05
    St. Louis, Missouri
    3,135
    Try doing a Save-as of the Central, give it a new name. See if the user can then open it and create a new local.
    St. Louis, MO
    2006-03
    Tacoma, Wa
    639
    I'll give that a shot but I'm already skeptical since this problem exists on any other project he tries to open.
    edit - Ok, had him do that, it gave an error message that the central model had been copied or moved, resave as new central. But it wouldn't let him do a save-as or anything.
    Tim McDougald
    HayWire Racing
    2004-05
    St. Louis, Missouri
    3,135
    Detach from Central 1st, then Save as with a new name. Then see if he can Open from Central and Create New Local. If not--something is WAY wrong. Revit re-install, wipe Windows, etc.
    If you create a brand new Project, can he open Central?
    St. Louis, MO
    2006-03
    Tacoma, Wa
    639
    OH. . . . . . . . MY. . . . . . . . GOD!!!!!! I have a headache.
    Aparently, the part I missed was that somehow his seat of Revit was in "Viewer" mode. Once I decided to shut it all down and reboot I no longer have this issue.
    Thanks guys, I do appreciate your prompt replies.
    Tim McDougald
    HayWire Racing
  1. 2014: Central Model Problems
    By joshea191409602 in forum Revit Architecture - General
    Last Post: 2014-05-19, 10:01 PM
  2. Connectors accessible through linked model
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-11-18, 03:40 PM
  3. Central file problems
    By callumusic670272 in forum Revit MEP - General
    Last Post: 2012-01-24, 05:16 PM
  4. Worksharing - Can't Synchronize with Central
    By laurenicole in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-05-05, 12:23 AM
  5. Central file connection problems
    By Gordon.Price in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2008-07-30, 02:44 AM
