Thread: Logical connections
    Wish List Administration
    2011-08
    4,581
    Default Logical connections
    Summary: Provide the ability to make logical connections between connectors.
    Description: Some examples where logical connections are usefull:
    - two cable trays are not always connected by means of a fitting but can nevertheless share a cable run. If a logical connection exists, one can show the relation by using the tab key.
    - during design, one does not want to get lost in the details. It sometimes takes twice as much time to actually draw complex situations of fittings when all you want to show is that they are connected. During construction, one can look at it in more detail and make the physical connection by means of fittings...
    - it should be possible to connect e.g. a fridge to an electrical socket. The power of the electrical socket could in that case be determined by the appliance (if opted for by the end user).
    other cases without connector:
    - a roof surface could logically be connected to a drain. In that case one can calculate the drain system based on the total connected roof surface. During detailed design, one could analyse the slope of the roofs to determine the total roof surface to be drained but that's way more complex to program and also not feasable during conceptual design.
    - and so on...
    logical connections are vital for revit!
    Product and Feature: Revit MEP - Other
    Submitted By: Wim Tas on 12/08/2012
    2011-08
    4,581
    Exclamation Re: Logical connections
    Logical connections
    - and so on...
    2011-08
    4,581
    Logical connections
    Description: Some examples where logical connections are useful:
    - Two cable trays are not always connected by means of a fitting but can nevertheless share a cable run. If a logical connection exists, one can show the relation by using the tab key.
    - During design, one does not want to get lost in the details. It sometimes takes twice as much time to actually draw complex situations of fittings when all you want to show is that they are connected. During construction, one can look at it in more detail and make the physical connection by means of fittings.
    - It should be possible to connect e.g. a fridge to an electrical socket. The power of the electrical socket could in that case be determined by the appliance (if opted for by the end user).
    Other cases without connector:
    - A roof surface could logically be connected to a drain. In that case one can calculate the drain system based on the total connected roof surface. During detailed design, one could analyse the slope of the roofs to determine the total roof surface to be drained but that's way more complex to program and also not feasable during conceptual design.
    - and so on...
    Logical connections are vital for Revit!
    2011-08
    4,581
    Logical connections
    - and so on...
  1. Logical decisions in table
    By luislhss in forum AutoLISP
    Last Post: 2013-06-03, 03:27 PM
  2. Logical Flow Connection
    By mjdanowski in forum Revit MEP - Wish List
    Last Post: 2008-07-28, 04:01 PM
  3. Filtering by logical OR rather than AND
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2007-07-25, 07:28 AM
  4. Logical Names for Corridors
    By jsnyder.105561 in forum AutoCAD Civil 3D - General
    Last Post: 2006-02-11, 03:39 AM
  5. logical drives and large disks
    By GuyR in forum Revit - Hardware & Operating Systems
    Last Post: 2005-11-07, 08:15 AM
