Results 1 to 10 of 10
Thread: Revit needs to have dimension to center of arc, circle/tube's edge
    I could stop if I wanted to Richard McCarthy's Avatar
    2003-07
    237
    Default Revit needs to have dimension to center of arc, circle/tube's edge
    Revit needs to have dimensioning to center of arc / circle / tube's edge, etc etc.
    Right now it's kinda fiddily.....
    2003-05
    5,153
    Default Re: Revit needs to have dimension to center of arc, circle/tube's edge
    I'm not sure what's fiddly about it.
    1. Pick arc, circle etc . Temporary radial dimension appears. Pick to make permanent. ( = 2 clicks )
    or
    2. DI ( shortcut dimension key ) . Select Radial Dimension button. Place radial dimension. ( = 3 clicks, counting the keyboard shortcut as one )
    Seems quite fast to me.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Or to dimesion out the centre point. select the object (wall or line), go to its properties, tick show centre point then dimension to this...
    HTH.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-05
    5,153
    Yes, by picking "make permanent symbol" when the temporary dimension appears from the centre mark.
    Quote Originally Posted by Mr Spot
    HTH.
    2003-07
    237
    My apology, I didn't explain it well, what i mean is to dimension to the model's edge.
    One example is disabled toilet hand rails. You can't dimension to the 'tip' of the hand rail (half spherical part...) or the edge of the rail (because it's a 3 dimensional model and Revit somehow have hard time pick up those fiddily edges even though you are in plans, elevations or section)
    2003-05
    5,153
    As long as you start the dimension from a plane parallel and orthogonal to the plane on the curved model to which you want to dimension and provided the model has a reference plane defined at the point at which you wish to dimension, you shouldn't have a problem.
    If the model of a grab rail was created with reference planes only at its centre point, you will not be able to dimension to its face. You can easier fix that though by adding those RP's to the family.
    2003-05
    Colorado Springs, CO
    97
    In a different vein. I believe we need a dimension tool that let's us dimension arcs parallel to each other. Or is there a way we can do that already, too?
    2003-05
    5,153
    Do you mean like this, Trent ?
    Quote Originally Posted by Trent Piazzoni
    2003-05
    97
    That's good thought but what about parallel arcs not at quad points? I've been having dimension streets lately and the lack of this feature is drive me nuts.
    2003-05
    5,153
    Yes, that could be improved. Currently you must place detail linework to dim to, then make those construction lines invisible.
  1. Add Leader to Circle Dimension
    Last Post: 2014-10-22, 06:55 PM
  2. circle and center marks
    By sherflor in forum AutoCAD General
    Last Post: 2013-07-19, 02:40 PM
  3. Dimension the diameter of a circle
    Last Post: 2013-05-16, 08:33 AM
  4. 2013: Aligning center point of circle and changing its radius
    By engamrsalah in forum Revit Architecture - Families
    Last Post: 2013-01-29, 05:10 PM
  5. Place a plane on a tangent edge of a circle with a parallel surface or edge.
    Last Post: 2010-09-22, 12:51 PM
