As a novice, i have "learned" to make drawings of assemblies using manual method vs. using "Automatic Drawing ".
I sucessfully made drawing of 5 Position Assemblies with seperate details of all plates attached to main
profile member. The assembly detail was put on the template drawing sheet using the "Add as a block
to the current layout". Each plate position was made into a drawing and moved to the template drawing.
I made changes to the assembly layout detail dimensions to improve "read ability". the part layouts were also changed for the same reason.
Problem 1.
I started to make a detail drawing of another Assembly Position (B19). I think I used the same procedure to generate layouts of the assembly and all parts as before but something is wrong. The assembly & beam layout drawings will transfer to the drawing sheet. All plates are noted as drawings in the Object Inspector, but when I use the "Adds as a block to the current layout", the
Command: RBCT_ADDALLBLOCKREFTOPRING
REGENERATING MODEL
COMMAND: regeall
The plate layouts do not transfer to the drawing.
What could cause this error to happen?
Problem 2.
No bolts are shown in the bolt list.
