Thread: Insert a Tool Palette Block While Editing a Block or Xref.
    Wish List Administration
    2011-08
    4,581
    Default Insert a Tool Palette Block While Editing a Block or Xref.
    Summary: I would llike to be able to insert a tool palette block while I am actively editing a a block or xref.
    Description: I wish I could insert a tool palatte block while I am currently editing a block or an xref. Currently you have to either insert a block by using the ddinsert command or exit the editing session, insert the tool palatte block, edit the block or xref you were trying to insert the tool palatte block into and add it to the working set. A truly cumbersome procedure, if you ask me.
    Product and Feature: AutoCAD - Blocks
    Submitted By: Jeff Beck on 12/10/2012
    2011-08
    4,581
    Exclamation Re: Insert a Tool Palette Block While Editing a Block or Xref.
    Summary: I would llike to be able to insert a tool palette block while I am actively editing a block or xref in the refedit command.
    Description: I wish I could insert a tool palatte block while I am currently editing a block or an xref in the refedit command. Currently you have to either insert a block by using the ddinsert command or exit the editing session, insert the tool palatte block, edit the block or xref you were trying to insert the tool palatte block into and add it to the working set. A truly cumbersome procedure, if you ask me.
  1. Insert block with attributes from tool palette opens dialog
    By jpaulsen in forum AutoCAD Customization
    Last Post: 2006-09-29, 08:30 AM
  2. Insert a Block from a Tool Palette
    By chris.kulhanek in forum AutoCAD Customization
    Last Post: 2006-07-10, 10:57 PM
  3. Insert a block from a Tool Palette and pre-specify Attribute value
    By andy.89024 in forum AutoCAD Customization
    Last Post: 2006-05-09, 10:46 AM
  4. Tool Palette - Object by default Inserts as Block, change to Xref instead?
    By costas.vassiliou in forum AutoCAD Customization
    Last Post: 2006-03-07, 09:53 AM
