Thread: Need help with dimension parameters
    2009-10
    36
    Default Need help with dimension parameters
    Hello,
    I'm having troubles getting this family from the manufacturer. So I created a quick & dirty pipe accessory family.
    It's not perfect or close to it. But it will do.
    I'm able to add the "A" dimensions Could somebody please help & add dimensions "B, C, D & E" for the different sizes.
    All AUGI, all the time JoelLondenberg's Avatar
    2015-10
    508
    Default Re: Need help with dimension parameters
    Attachments???
    2009-10
    36
    Sorry about that. Let's see if this works now.
    2015-10
    508
    Based on a very quick review:
    - you have way too few reference planes / lines
    - you have way too many features, almost none of that detail will be visible in typical plan views - that should be your target detail wise
    It looks like you are relatively new to building complex flexible families. Keep at it, ask more questions like this, watch videos from Autodesk University (if you can). If you want a flexible family, I recommend starting over with reference planes and lines laid out with the flexibility tested before you begin adding any geometry.
    If you want quick and dirty, just save as to a new family for different sizes and stretch the bits needed.
    2009-10
    36
    Joel,
    Yes I am very new to building complex flexible families. I might do the quick & dirty way for now. Save families with different sizes.
    Thank you
  1. 2014: Duct Fittings - Default dimension parameters
    By slovenc0417 in forum Revit MEP - General
    Last Post: 2014-04-18, 12:17 AM
  2. Use Parameters in dimension expression
    Last Post: 2012-06-12, 02:17 AM
  3. Change fixed "Type" parameters to "Instance" parameters.
    By autocad.wishlist1734 in forum Revit MEP - Wish List
    Last Post: 2011-10-10, 11:52 AM
  4. Where are the dimension Parameters?
    By Dave F. in forum Revit Architecture - Families
    Last Post: 2009-03-03, 04:26 PM
  5. Linking door and window parameters to room parameters
    By Mangrove in forum Revit Architecture - Families
    Last Post: 2008-12-03, 08:27 PM
