Thread: Recursive roof from polylines
    2012-12
    Default Recursive roof from polylines
    Hi,
    I am new to lisp but I have experience with other programming languages.
    I am trying to create roof meshes from a number of polylines, there are thousands, so I am trying to write a simple script to get the job done.
    here is what I have so far
    (defun roofmaker( / sset item ctr)
    (while
        (setq sset (ssget))
        (setq ctr 0)
        (repeat (sslength sset)
            (setq item (sset ctr))
            (command "_.roofconvert" item "" "n" )
            (setq ctr (1+ ctr))
        );repeat
    );while
    );defun
    Because I can't apply the roofconvert command to a set of polylines I have go through the selected set one object at a time and run that command.
    Right now I am getting an error, I am guessing it something to do with the selection list but I am not sure.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Recursive roof from polylines
    Adjust this line
    to include the ssname function
    (setq item (ssname sset ctr))
    Moderator BlackBox's Avatar
    2,392
    Firstly, welcome to AUGI!
    Couple of things....
    In order for your LISP to register as a Command (something you can enter at the Command line, etc.), your Defun statement's Symbol requires a "C:" prefix (not case sensitive).
    What error are you receiving specifically? That's usually helpful in offering advice.
    As I do not have any architectural software to look up for myself, you might consider this adaptation (untested):
    (defun c:RoofMaker (/ ss i)
      (princ "\rROOFMAKER ")
      (if (setq ss (ssget "_:L" '((0 . "*POLYLINE"))))
        (repeat (setq i (sslength ss))
          (command "_.roofconvert" (ssname ss (setq i (1- i))) "" "n")
        (prompt "\n** Nothing selected ** ")
    Lastly, if you already possess development experience with other languages, consider looking into your application's available API's as most (not all) support a COM, and .NET API.
    Hope this Helps (HTH)
    "Potential has a shelf life." - Margaret Atwood
    2012-12
    Thanks, RenderMan
    that did the trick.
    definitely, extracting each object from the list was the culprit. I was not sure how lisp stores objects in a list or how it retrieves them.
    Don't really deal a lot with autocad, just needed to get this one problem solved quickly for a project I'm working on - Autocad had the roof generator I needed,
    otherwise it would have needed to write a much larger script to calculate roof slopes and 3d intersections and etc. in another environment.
    2,392
    Quote Originally Posted by ilya346445 View Post
    Thanks, RenderMan
    that did the trick.
    You're welcome; I'm happy to help.
    When dealing with LISP, major tasks often involve iteration of Selection Sets, or Lists (sometimes of Lists)... Repeat will give you the best performance when dealing with AutoLISP Lists, and for iterating Visual LISP Collection Objects (i.e., DocumentCollection, ActiveSelectionsSet, etc.), then Vlax-For is the ticket.
    Again, not sure of the languages you're familiar with, but AutoCAD supports both .NET (C#,F#,VB.NET) API, and ObjectARX (C++ for AutoCAD) API... Even though I'm progressively doing more and more .NET development (verticals such as Civil 3D are somewhat forcing that), LISP is still the quickest bang for the buck in my work.
    Let us know if we can help out with anything else - Cheers!
  1. Polylines with arcs to polylines with segments
    By randyspear in forum AutoCAD General
    Last Post: 2009-04-15, 06:22 PM
  2. Replies: 7
    Last Post: 2008-02-22, 03:13 PM
  3. How to change LW PolyLines to 2D PolyLines
    By Lions60 in forum AutoLISP
    Last Post: 2007-07-13, 05:58 PM
  4. How to convert 3D Polylines to 2D Polylines
    By GreyHippo in forum AutoLISP
    Last Post: 2007-01-04, 04:32 PM
