Thread: maya to inventor
    Default maya to inventor
    hello, i have several models in maya. and i want to use these models in inventor as solid (fill) structure. is there any way to do this? when i export polygon meshes .iges from maya and import them to inventor there's nothing!
    i tried to convert polygon meshes to nurbs surfaces in maya. bu it doesnt work properly. models get disrupt.
    also there's a format .stl but i dont know how can i use it between maya and inventor.
    Could you please anyone help me?
    in the upper right corner
    3,507
    Default Re: maya to inventor
    I don't know anything about Maya, but can you export out to a step file (.stp)?
    If you can, Inventor can read that.
    thank you. i'v solve the problem converting polygon meshes into nurbs surfaces. step doesn't realise polygons.
  1. 3DS or Maya??? Help!
    By CADDmanVA in forum DV - The 3rd Dimension
    Last Post: 2007-11-21, 12:32 PM
  2. From Maya to Inventor and Back Again
    By Daniel LeFebvre in forum Inventor - General
    Last Post: 2007-03-12, 01:59 PM
  3. 3D Max 6 and Maya 5 ?
    By CadVizion in forum Revit - Rendering
    Last Post: 2006-10-24, 07:00 AM
