Results 1 to 8 of 8
Thread: Aligning center point of circle and changing its radius
    2012-12
    6
    Default Aligning center point of circle and changing its radius
    Hey Guys,
    I want to pin the center of an arc to a reference line/plane and also have the option to change its radius. I can change the arc radius which will move the reference line too but when i pin the the center of the arc to that reference line, i can not change the arc radius. Kindly see attached file and thanks in advance.
    Regards
    Amr Salah
    2015-11
    Madison, WI
    1,318
    Default Re: Aligning center point of circle and changing its radius
    Hello Amr,
    Welcome to AUGI. Looking at your family, you need to constrain the center of your arc to the reference lines. Easiest way to do this is to use the Align (AL) Command, first selecting the reference line/plane, then selecting the center mark of the Arc. Your labelled radial dimension will control the arc's radius.
    I hope this helps,
    Jeff S.
    2012-12
    6
    Hello Jeff,
    Thanks for your reply, I've already aligned the center of the arc to the reference plane but when i change R value, it makes an error. the attached file after locking the center of the arc, kindly try to change R value and see the error.
    Regards
    Amr Salah
    2015-11
    Madison, WI
    1,318
    Amr,
    When I tried this yesterday it worked directly from your file, this morning not so much. Although starting from scratch, I was able to quickly get it to work. Personally, I like to use reference planes over reference lines, depending on the family. Anyways, I created a short video demonstrating how I approached this. The file is saved as a zip to allow me to upload it to AUGI. Download it, extract it, watch it, and ask more questions if you need clarifications.
    Cheers,
    Jeff S.
    2012-12
    6
    Interesting that i did what you did in the video and it works!!!!!!!!! it is almost the same i did before but i do not know why it now worked and not before!!!!!! anyway I can not thank you enough for your efforts, the video was a great help, nice to meet you.
    Thanks again Jeff.
    Regards
    Amr Salah
    2015-11
    Madison, WI
    1,318
    best of luck on your future Revit family adventures. I'm glad I could help.
    Cheers,
    Jeff S.
    2005-09
    VARANASI in India
    338
    Jsteinhauer
    May I know which software you use to capture the screen shots for making video ?
    2015-11
    Madison, WI
    1,318
    Hello ljupadhyay,
    Sorry for the delay in responding, I haven't checked the families forum in a few weeks. I use a product by Techsmith called Camtasia Studio for video capture/editing/production. They also have an product called SnagIt which I have installed, and use for image & text capture. There is a video capture component to SnagIt, but I prefer Camtasia.
    Cheers,
    Jeff S.
  1. circle and center marks
    By sherflor in forum AutoCAD General
    Last Post: 2013-07-19, 02:40 PM
  2. command Circle>Tan Tan Radius Autolisp
    By TUD_DUT in forum AutoLISP
    Last Post: 2012-10-23, 09:23 PM
  3. Allow aligning center of foundation with axe or set offset
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-07-06, 05:17 PM
  4. Undo Within the Tan-Tan-Radius Circle Command
    Last Post: 2009-02-01, 05:11 PM
  5. Replies: 10
    Last Post: 2007-03-23, 01:50 AM
