Thread: Presenter - Assign material to selected
    All AUGI, all the time Bryan Thatcher's Avatar
    2007-09
    Raleigh NC
    755
    Default Presenter - Assign material to selected
    When I assign a material to all selected objects, it only holds on the objects in that one view port. When I switch view ports it reverts back to the default colors. How can I fix this? Thanks.
    Bryan Thatcher
    Structural Design Technician
    Clark-Nexsen Architecture & Engineering
    2009-02
    Brisbane, Australia
    127
    Default Re: Presenter - Assign material to selected
    If you meant viewpoints as opposed to viewports, it could be that your viewpoints are all set with render style set to "shaded", then when you add a material the display automatically sets render style to "full render" so you see the materials as applied, but then when you switch to another saved viewpoint with render style set to "shaded" the materials will seem to disappear. Even going back to the first viewpoint where materials were displayed will not show the materials if the viewpoint's render style is saved as "shaded". You need to change the render style to "full render" and update the viewpoint with this setting.
    2007-09
    Raleigh NC
    755
    Ah! I see. Next question. Is there a way to set up a template to be used when I generate viewpoints from the Report tab? Thank you.
    Also, how can I save a viewpoint rendering option. When I switch views and return, the rendering is set back to shaded.
    Bryan Thatcher
    2009-02
    Brisbane, Australia
    127
    Sorry can't help with the first question regarding reports, but saving the rendering option is as simple as updating the viewpoint i.e. right click the viewpoint and select update to save current settings. You set the rendering style mode from the Viewpoint Ribbon Tab.
  1. 2014: Presenter Material defined by image file
    By bwiab in forum NavisWorks - General
    Last Post: 2013-07-02, 05:11 PM
  2. problem avec assign material dans 3ds max
    By anouar_rr in forum Français - 3ds Max / Maya
    Last Post: 2009-05-01, 08:17 AM
  3. applying presenter material
    By vigneh in forum NavisWorks - General
    Last Post: 2009-04-18, 10:15 PM
  4. Assign a material to AEC/Muti-View blocks?
    By cadlivin in forum ACA/AMEP Styles Library
    Last Post: 2008-02-23, 12:17 AM
  5. Assign Material to Multiple Layers in One Step
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2007-04-02, 07:48 PM
