Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Void only Cutting half of an extrusion
    2012-09
    Pittburgh, PA
    49
    Question Void only Cutting half of an extrusion
    I have a family with one nested inside. The host family consist of one extrusion and one void extrusion. Now once the other family is nested and the extrusion passes through it the void doesn't cut the extrusion anymore and it sticks out on the other side of my family. What should I do to fix or change this? I have posted a copy of the family below.
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Void only Cutting half of an extrusion
    It looks like you'll have to reestablish the cut. Just go to Modify tab » Cut ▼ Cut Geometry, select the void extrusion, and then the solid extrusion.
    2012-09
    Pittburgh, PA
    49
    will the orange from the void extrusion go away eventually?
    2012-01
    813
    It should once it's cutting an extrusion. A Void will be visible and orange only if it isn't cutting anything (either because it isn't assigned to cut any extrusions or it doesn't overlap any applicable extrusions). I opened your Family and followed this procedure - no problem; the orange is gone. Is it still showing up for you?
    2012-09
    Pittburgh, PA
    49
    yes, but only when the yes/no parameter three qtr is checked the other two it is fine
    2012-01
    813
    Right, because the Void is no longer cutting the extrusion. That's OK, though, because the orange will not visible when then Family loaded into a Project.
    2012-09
    Pittburgh, PA
    49
    it still does something weird when loaded into the project but I think has more to do with the fact that i use a convaluted mess of a formula that makes no sense
    2012-01
    813
    You're formula's not that bad! I'm not seeing the issue, can you elaborate on what's weird? Maybe a screenshot?
    2012-09
    Pittburgh, PA
    49
    When the panel is loaded into a wall hosted family the void still shows up but not if it is loaded into a project is it just going to be like that because it is a family?
    2012-01
    813
    That's strange. The void should not be visible, even if loaded into another Family. Try loading it into a Project and see if it shows up there.
  1. 2009: Void Extrusion
    By SBH1730 in forum Revit Architecture - General
    Last Post: 2012-03-07, 02:03 AM
  2. Changing Void to Extrusion
    By Alex Page in forum Revit Architecture - Families
    Last Post: 2010-09-14, 01:19 AM
  3. Void Extrusion
    By r.c.russell in forum Revit - Student Support
    Last Post: 2009-06-13, 10:15 AM
  4. generic model , void form, void extrusion
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-01-29, 01:59 PM
  5. Void extrusion help
    By Kirk Bricker in forum Revit Architecture - Families
    Last Post: 2006-05-02, 11:01 PM
