I need to make an electrical panel schedule that only has 30 breaker spots. If I change the amount of single pole breakers in the panel, it does not change the panel schedule. Does anyone know how to edit these to make them less than 42 circuit?
Manage tab » Panel Schedule Templates ▼ Edit a Template. Open your Panel Template and then go to Set Template Options on the top left on the Ribbon. Under Size, set it to "Variable based on maximum number of one-pole breakers". You will likely have to refresh the existing Panel Schedule Views by opening them, clicking Change Template on the Ribbon, and selecting that same Template.
