Thread: How to use this Formula,"Formula That Returns Strings"?
    2007-09
    83
    Default How to use this Formula,"Formula That Returns Strings"?
    I got this in the wikihelp, "Formula That Returns Strings","IF (Length < 900, “Opening too narrow”, “Opening OK”)"
    but how to use it?
    Is that the string will pop up like a message box?
    2015-11
    Jo'burg SA
    4,512
    Default Re: How to use this Formula,"Formula That Returns Strings"?
    You use it as the formula in something like a parameter. E.g here's a sample of a door family's parameters using formulas:
    You use that IF function when the parameter you place the forumla into is a text parameter. E.g. say you'd want to indicate in the Door's param what type of lintel is used depending on the width of the door. So here I add a Text Parameter
    And then adding even nested if's to show more options:
    2007-09
    83
    thanks, I'll try it again
    2007-09
    83
    I got this, thanks a lot
    2015-11
    Jo'burg SA
    4,512
    Pleasure. Glad to help.
  1. 2013: 2"/4" Door Head (formula driven)
    By schaff.kaleb in forum Revit Architecture - General
    Last Post: 2013-05-06, 07:25 PM
  2. Formula using "Original Value"
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2010-09-14, 01:33 AM
  3. Formula: how to check if room is "Not Placed"?
    By studiodd in forum Revit Architecture - General
    Last Post: 2009-01-19, 01:55 PM
  4. Formula Property Definition : "Sample Result"
    By julien.hofman in forum Style Management
    Last Post: 2008-08-01, 10:18 AM
  5. Formula Array "Snap" to a given size?
    Last Post: 2008-04-04, 05:51 AM
