Thread: Dimension Text has Perpendicular Line at end of text only when printed.
    2004-08
    Raleigh, NC
    118
    Default Dimension Text has Perpendicular Line at end of text only when printed.
    I have a file with several dimension that are printing a perpendicular line only when printed. Not sure where it is coming from. Any help would be appreciated. I am uploading image & DWG for your use.
    2015-12
    Chesterfield, MI
    405
    Default Re: Dimension Text has Perpendicular Line at end of text only when printed.
    I was unable to duplicate your issue. I printed to PDF, DWF and Hardcopy without seeing those line segments.
    Do you see this regardless of the method or device that you use?
    2004-08
    Raleigh, NC
    118
    Quote Originally Posted by bcgatti View Post
    Interisting. The image was taken from the PDF, it appears when printed directly to Kip plotter and to printers. Also occurs on two additional computers.
  1. 2013: Need dimension line with no text/value
    By jonashcdk790148 in forum Revit Architecture - General
    Last Post: 2012-11-09, 01:52 PM
  2. Replies: 0
    Last Post: 2008-12-11, 07:27 AM
  3. Position dimension text always! perpendicular to the arc
    By usmc_soccer in forum AutoCAD General
    Last Post: 2006-03-03, 10:53 PM
  4. Position dimension text always! perpendicular to the arc
    By usmc_soccer in forum AutoCAD LT - General
    Last Post: 2006-03-03, 03:05 PM
  5. Add text below a dimension line
    By huascarfdez in forum AutoCAD Tips & Tricks
    Last Post: 2005-04-01, 08:08 PM
