FIRST: VISRETAIN IS SET TO (1) IN EACH DRAWING.
SECOND: "Retain changes to xref layers" is checked in Options
THIRD: All drawings are xref'd in as ATTACHMENTS
So, I have a drawing file that is called xDim. In it, are 2 xref'd files; xAFP.dwg and xAFP-exist.dwg. xDim is a Dimension Plan (betcha couldn't guess that) that I have all the xAFP-exist layers turned to color 30 and all the furniture both existing and in the xAFP drawing frozen as well as all "demo" layers frozen.
When I try to xref xDim into a new drawing, ALL the layers come in in the state they were last saved in their respective drawings. So, for example,all the demo layers are thawed from the xAFP-exist drawing and all the layers from that drawing are in their original colors, not color 30 as they are set in xDim.
Am I imagining things?...but I thought that I could set xref layers in a drawing and then xref that drawing in and it would bring those settings. Is that not true?
FYI I am only xrefing in xDim into multiple sheets because it is too big to fit on one sheet...otherwise I'd just put the title block in that drawing. I don't want to have to set all my layers in each drawing I xref that into each time.
I am happy to look at other posts if you can direct me. My searches did not turn up this exact issue.
Thank you much!
