Thread: Output multiple high res viewports
    2012-03
    Default Output multiple high res viewports
    Is there a way to output a selection of viewports instead of clicking on each one then hitting output>image ? I have 50 views that I want to output and would prefer not to do this one by one. The viewport report is kind of useless as it prints all the images in really low resolution. Its says that I can customize the report by editing viewpoints_report.xsl, but i have no idea how to do that...
    2013-01
    8
    Default Re: Output multiple high res viewports
    Hi,
    I've exactly the same problem. The file "viewpoints_report.xsl" is in the Navisworks installation directory (you can open it with a notepad for example). In my case it was in "C:\Program Files\Autodesk\Navisworks Simulate 2012\fr-FR\stylesheets".
    I opened it and tried to find a line concerning the resolution, but didn't find anything related to...
    If anyone as the solution !
    I could stop if I wanted to brenehan's Avatar
    2007-02
    Melbourne
    225
    What is the resolution in your Viewpoint Report?
    If we change the Viewpoint Report to push out a Viewpoint at 1024 x 1024 .PNG @ Anti-Aliasing Passes of 4 it should be OK.
    In order to change the resolution go the Application Menu (The big "N" in the top left corner), and hold the "Shift" key down while clicking on the "Options" button.
    Then in the Viewpoint Defaults setting you can change the Viewpoint Report resolution.
    Brian Renehan
    BIM Consultant
    Melbourne - Australia
    http://bimfix.blogspot.com
    2013-01
    8
    Yeaaah! Thank you that works !
    I had done the same but hadn't held the "Shift" key.. so I couldn't see this parameter.
    Bye
  1. Views and Viewports across multiple drawings
    By curtisac8 in forum AutoCAD General
    Last Post: 2010-10-15, 08:42 PM
  2. Multiple Viewports with Different Scales: Glitch??
    By Treed.255529 in forum AutoCAD Civil 3D - General
    Last Post: 2010-07-08, 04:40 PM
  3. multiple viewports in layout for 3D or 2D
    By Richard.Kent in forum AutoCAD Tips & Tricks
    Last Post: 2009-05-15, 11:20 PM
  4. Dimension across multiple viewports
    By joeswantek in forum AutoCAD General
    Last Post: 2007-05-25, 02:21 PM
