Results 1 to 1 of 1
Thread: How to extend top or base of a wall layer when the wall ends wrapped and not joined to other wall?
    2008-07
    Gold Coast, Australia
    Default How to extend top or base of a wall layer when the wall ends wrapped and not joined to other wall?
    Hi,
    I tried to figure out this by searching webs but I couldn't find answer.
    My situation is below.
    1. There are two walls meet at the corner and sit on slab.
    2. Both walls are different types and are not joining. (Disallow Join)
    3. Ends of one of the wall set to wrap. (Wrapping at Ends - Exterior)
    4. And, the external layer (brick) of that wall extended to the bottom of the slab (Base Extension Distance = Thickness of slab)
    My problem is, when I did above process the wrapped part (ends) of the external wall layer didn't extend to the bottom of the slab. Images are attached.
    Anyone knows how to fix this problem? I appreciate you in an advance for the help.
    K.
  1. 2012: How to extend top or base of a wall layer when the wall ends wrapped and not joined to other wall?
    By architekz.188213 in forum Revit Architecture - General
    Last Post: 2013-01-24, 08:46 AM
  2. 2013: Extend one layer of exterior wall?
    By emnight87 in forum Revit Architecture - General
    Last Post: 2013-01-02, 02:50 PM
  3. Align ends of wall sweeps with profiled wall
    By detroit.architecture in forum Revit Architecture - General
    Last Post: 2010-10-19, 02:33 AM
  4. Precast base as joined but separate wall: problems
    By Gordon.Price in forum Revit Architecture - General
    Last Post: 2008-08-21, 01:15 PM
  5. Beginner Question - Wall Joins, Wall Ends
    By jalexander.108656 in forum Revit Architecture - General
    Last Post: 2006-03-24, 07:33 PM
