Thread: Lost Schematic Plumbing Elbows
    2009-01
    4
    Default Lost Schematic Plumbing Elbows
    I've been working on a new template for 2012 AMEP. Some how I lost the schematic plumbing elbows styles (all). If I switch to a mitered fitting they apear. Selecting the mitered fitting, then edit the fitting style through the properties pallet, even the edit fitting dialog preview referencing elbow fittings are missing from the display? Is it possible I deleted the dedicated layer/s for schematic elbow styles when clean up the template?
    2009-01
    4
    Default Re: Lost Schematic Plumbing Elbows
    Display configurations dose not effect display
    Qnew OOTB templates elbow are visable
    All setting apears to be correct throught out the Display/Style Manger including the Layers.
    Really wanted to discover how this happened..
    I ended up deleting the problematic fittings and copied them in from another drawing- Case solved I guess..
  1. Replies: 1
    Last Post: 2013-10-26, 09:18 PM
  2. Elbows in 2D plumbing line
    By che in forum AMEP General
    Last Post: 2008-06-17, 12:33 PM
  3. 8.1/E Leader elbows - O
    By sfaust in forum Revit Architecture - Wish List
    Last Post: 2006-03-28, 05:54 PM
  4. Problems with sizing schematic plumbing
    By vookky in forum AMEP General
    Last Post: 2005-01-19, 09:23 AM
